2020 Mustang Mach-E Features
  • Mustang Mach-E GT Performance Edition brings the thrills Mustang is famous for, targeting 0-60 mph in the mid-3-second range and an estimated 342 kW (459 horsepower) and 830 Nm (612 lb.-ft.) of torque
  • Mustang Mach-E instills confidence, targeting an EPA-estimated range of at least 300 miles with the available extended-range battery and rear-wheel drive, offering built-in charging solutions that route customers to nearby public charging stations, recommending where to charge on trips, and providing access to over 12,500 public charge stations in the FordPass charging network
  • When it arrives in late 2020, Mustang Mach-E will be available with standard and extended-range battery options with either rear-wheel drive or all-wheel drive powered by permanent magnet motors. Equipped with an extended-range battery and rear-wheel drive, Mach-E has a targeted EPA-estimated range of at least 300 miles.1 In extended-range all-wheel-drive configurations, Mach-E is targeting 332 horsepower and 417 lb.-ft. of torque – with the standard all-wheel-drive variation targeting quicker times to 60 mph than the base Porsche Macan series.
  • Ford also will offer two special performance versions. The GT is targeting 0-60 mph in under 4 seconds, making it faster off the line than a Porsche Macan Turbo. The GT Performance Edition, meanwhile, is targeting a comparable 0-60 mph in the mid-3-second range to a Porsche 911 GTS.3 Both GT configurations are targeting an estimated 342 kW (459 horsepower) and 830 Nm (612 lb.-ft.) of torque.
