How to charge the Mustang Mach-E at home? Charging time introduction
Los Angeles
mache2024
Ford Mustang Mach-E is divided into two versions according to battery capacity: 72kwh and 91kwh. For electric vehicles, charging at home is the most convenient.
Ford has a 240V48A home charging station, which costs $799. The price is high and the cost performance is not high.
In fact, you can also use Ruivanda home charging station, which costs only $399 for a 240V48A charging station. 220✖️48=10.5kw, which means that 10.5 kWh can be charged at full load in one hour.
Theoretically, the time from 0 to full charge for the MachE 72kwh version is 72kwh➗10.5kw=6.8h;
The time from 0 to full charge for the MachE 91kwh version is 91kwh➗10.5kw=8.6h.
Using the Ruivanda charging station, you can directly plug it into a 240V NEMA 14-50 wall socket. Because the battery is generally not completely used up before charging, the charging current can be lowered, which will be safer.
Similar threads
