I use a Ruivanda home charger, which can be directly plugged into a 240V NEMA 14-50 wall socket. The maximum charging power is 240v✖️48A=10.5KW, which means 10.5 kWh of electricity per hour. Since the battery is generally not completely used up before charging, the charging current can be lowered, which will be safer.
